Thread: Where to get Mild Steel Plate?
30-12-2016 #11
Chaz,
Plug welding is welding through a hole and "plugging it".
Drill a pattern of holes diameter 2x thickness in one plate, clamp it to a second plate and weld through the holes in the first to the second plate and the hole walls, finishing by filling the holes then grinding flush.
Add further plates in the same way until the desired thickness is achieved, you could optionally weld around the outside,
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
