Thread: UC300 Ethernet
    Hi does anyone know anything about these boards? How do they compare to the Smoothstepper? Customer service any good?
    UC300ETH vs Smoothstepper
    UC300ETH has more I/O (5 ports vs 3 ports)
    UC300ETH has dedicated analog I/O
    UC300ETH has better plugin support. Fast bug fixes, and always up to date
    UC300ETH also works with UCCNC software, which is in many ways superior to Mach3. And much cheaper.
    Support is excellent, either through email or the UCCNC support forum. Note, however, that the forum is mainly for the UCCNC software.
    The ESS can potentially proved a 10x faster pulse rate, though. 4Mhz vs 400Khz for the UC300ETH.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Ok
    Thanks for the reply...
    So the UC300 pulses at only 400,000Hz (four hundred thousand cycles per second).... What real world difference does this make?
    400,000 for the UC300ETH
    4,000,000 for the ESS.
    Those are maximums, and you'd typically set them at lower settings, unless you need 4 million steps/second.
    Most drives won't even work at those speeds.
    Gerry
    Clive S's Avatar
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by noyloj View Post
    Ok
    So the UC300 pulses at only 400,000,000Hz (four hundred million cycles per second).... What real world difference does this make?
    Do you mean 400,000Hz
    Yes just spotted my error...
    So no real world difference then?
    I've got HSS86H closed loop hybrid drives that only run at 200KHz so shouldn't be any kind of issue... BTW does anyone know where I can get hold of the closed loop software? The links don't seem to be active on the JMC downloads page...
    Ok
    In my opinion no difference at all. That is, unless you have super fast, very expensive drivers. My drivers (DQ542MA) can handle up to 200kHz. They can be used with 400kHz as well but because that's outside the specs I don't think it is a good idea, so I use mine with 200kHz.
  9. The Following User Says Thank You to A_Camera For This Useful Post:
  10. #9
    Am I correct in thinking that one pulses equals one step?
    If so then I pulse equals 1.8 degrees... therefore 200 pulses equals one full rotation... One full rotation equals 5mm (with my Chinese 1605 and 2005 ballscrews)....
    200,000 pulses (200KHz)/ 200 pulses x 5mm = 5000mm/s = 5m/s theoretical maximum velocity...
    Is this correct?
  11. #10
    That depends on your microstep settings on the drive.
    Gerry
  1. Uc300 motion controller problems
    By Hellfire in forum CNCdrive (UCCNC)
    Last Post: 07-11-2016, 07:21 PM
  2. Help mach3 ethernet set up
    By kell in forum Artsoft Mach (3 & 4)
    Last Post: 06-12-2015, 10:26 PM
  3. Grounding help, UCCNC, UC300 and connection loss
    By gabi68 in forum CNCdrive (UC100, UC300ETH)
    Last Post: 14-10-2015, 07:42 PM
  4. FOR SALE: uc300 motion control board slighly used
    By dazza in forum Items For Sale
    Last Post: 09-09-2015, 12:25 PM
  5. FOR SALE: uc300 motion control board slighly used
    Last Post: 09-09-2015, 12:23 PM
