Thread: MACH3 Plasma help please
03-01-2017 #10
Ok My bob is the PCL6x But is similar. I may be shot for this but I think it would work, In Mach go to ports and pins page then click on tab spindle setup. Then untick the flood/mist relays and enter say 3 in the for the flood relay you could control a relay with flood M8 to turn on and M9 to turn off in your gcode file.
Then under the (output signals tab) then set output #3 to port 1 and pin 16 (you might have to change active low)
You have to set SW3 to on on the BOB.
I stress I am not an expert in Mach3 so can somebody please check this
Edit: it took me so long to answer I did not see Deans post but he for sure will check the aboveLast edited by Clive S; 03-01-2017 at 04:15 PM. Reason: added text
plasma table running mach3 will run through g code but wouldnt move motors or dro
By whensparksfly in forum Plasma Table MachinesReplies: 1Last Post: 08-03-2016, 06:41 PM -
Plasma, Mach3, Sheetcam and a Proma Torch height controller..
By Davek0974 in forum Plasma Table MachinesReplies: 2Last Post: 14-04-2014, 03:49 PM -
My first CNC plasma
By Walterronny in forum DIY Plasma Build LogsReplies: 30Last Post: 20-02-2013, 02:13 AM -
Brit made plasma THC for Hypertherm / Mach3 users
By stirling in forum Manufacturer NewsReplies: 3Last Post: 13-02-2013, 09:58 AM -
plasma cad
By jamied in forum Computer SoftwareReplies: 6Last Post: 20-08-2010, 03:33 PM
