Thread: Warco WM16 CNC Conversion.
04-01-2017 #11
That's handy, thanks! I think JMC do a 3 Nm Nema24 60HSE closed loop hybrid stepper motor... but I'm not sure it will be compatible with the 2HSS86H drivers... The motor specs are quite similar as regards resistance, step angle, etc... only the inductance seems to be lower... any idea if I can use these together?
Warco WM16 Mill - Conversion to AC motor with VFD
By birchy in forum Milling Machines, Builds & ConversionsReplies: 16Last Post: 10-02-2022, 07:41 PM -
Warco WM16 Conversion
By birchy in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2011, 09:32 PM -
Warco mini mill cnc conversion
By buster in forum Milling Machines, Builds & ConversionsReplies: 22Last Post: 20-03-2011, 07:48 PM -
CONVERSION: Warco VMC Turret Mill - CNC Conversion
By antsals in forum Conversion Build LogsReplies: 33Last Post: 07-03-2011, 12:25 AM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM
