Thread: Warco WM16 CNC Conversion.
Windows 10 update is working now with the dotnet 2.0 framework.
UCCNC auto updated the firmware on the UC300 so they are playing nicely for the moment! I am using a direct connection from the laptop not through a router or switch... so I used a network crossover Ethernet cable not a straight one...
Wm16 Mill arrived today and I managed to split it into two and lug the pieces upstairs with the help of my neighbor.... Gonna have to find a good table or weld up a stand for her... The stand is probably the way forward... I've got some angle kicking about here somewhere... Could probably make it simply a skeleton and add sides and cabinet and/or drawer at a later date...
Currently transferring (via Ethernet LAN) all media and music from my laptop to my desktop so that I can strip it and set it up to run the motion controller and UCCNC and Mach3 and probably some other CAD software and bits and bobs related to the mill conversion... Must remember to rejig the LAN IP address etc. settings when I swap back the Ethernet cable for the motion controller...Last edited by noyloj; 19-01-2017 at 10:01 PM.
21-01-2017 #2
Mill in bits all over the place now... quick way to familiarise oneself with a bit of kit and a chance to give it a good clean and lube... Plenty of paint and sticky resiny oily varnish stuff everywhere including on the ways... dirt and grit and grinding residue too.
Quite surprised about the machining done to get the column perpendicular to the base... it looks like someone took a grinder to the machined mating surfaces! Will try and tidy this up after she's cleaned reassembled and I've put the dial to her...
Otherwise pretty much as I imagined except that the saddle looks to have been machined with the intention of fitting ballscrews and mounts... the hole for the x-axis clamp block is much bigger than I've seen and is just about perfectly sized for the cheapo Chinese mount I bought, also a shallow 1mm slot already milled in it that might allow enough clearance for x axis screw...
Warco WM16 Mill - Conversion to AC motor with VFD
By birchy in forum Milling Machines, Builds & ConversionsReplies: 16Last Post: 10-02-2022, 07:41 PM -
Warco WM16 Conversion
By birchy in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2011, 09:32 PM -
Warco mini mill cnc conversion
By buster in forum Milling Machines, Builds & ConversionsReplies: 22Last Post: 20-03-2011, 07:48 PM -
CONVERSION: Warco VMC Turret Mill - CNC Conversion
By antsals in forum Conversion Build LogsReplies: 33Last Post: 07-03-2011, 12:25 AM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM
