Thread: Cheap N Easy
Page 2 of 6 FirstFirst 1234 ... LastLast
    How about some pics, anything in cad yet?
    Yeah I have a few SVG of what I'd like to do.
    But been playing with concepts before I spend any more money. Have taken some photos of my mess.
    Bad pictures yes. 2nd x axis rail not in use atm.
    But it will have one. Y axis both rails in place.
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 619 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Well its different, it will be interesting to see it cut
    Well she moves real smooth. But it's nowhere near put together. It's literally clamped down.
    Waiting for couplings as had to test with cordless drill. Which worked a treat.
  5. #15
    From the look of your sprockets and chain you'll not be doing anymore cycling...😁
    Neil...
    Build log...here
  6. #16
    Rofl
    4x free wheel sprocket £2 or free of you have shed load of spare bits like I do. As for bike rides here's a pic of my little bike. Also the results of stupid tinkering.
  7. #17
    The tricky thing with chain drives is that the smaller sprockets give you terrible cogging and the larger sprockets give you enormous travel per rev requiring expensive low backlash gear boxes to get any king of resolution.
  8. #18
    Totally get that! Been doing countless searches on Sprockets and sizes to see what method would be best to resolve travel distance to rotation. Thinking i'd use some sort of gearing to compensate.
    small drive cog on stepper to a large cog attached to my "control bar" which would equal a zeroing out of the exterior cogs that connect to the chain.
  9. #19
    OK so i'm real crap at using sketch up.
  10. #20
    If you are serious at this you could design in Fusion360 it is free for hobby use, a big learning curve but it has CAM built in so you could use for generating the gcode later on.
    There are plenty of tutorials on it. like https://www.youtube.com/playlist?lis...Alt9yzBIp84sD8
  1. ELU 860 R 16 and Easy CNC Software
    By Martin Paul in forum Machine Discussion
    Last Post: 14-10-2010, 12:25 PM
  2. Easy money
    Last Post: 06-07-2009, 12:39 PM
  3. Easy & cheap high amp and volt PSU source
    By rinderpest in forum General Electronics
    Last Post: 18-05-2009, 07:45 PM
