03-01-2017 #12
Hi Chaz - that was the 2.2KW water-cooled variant.
As Jazz says if the bed was moving and allowing the cutter to take more than the desired 3.2mm then that might account for the spindle cut out. I've generally found that 8mm tools tend to survive very rough treatment, whilst 6mm and below don't. Last time I used an 8mm when something went wrong it welded itself into the plate and the machine then started walking itself off the table under spindle power, which was pretty scary, but the tool stayed intact.
I was even more grateful this time that the part wasn't ruined as I'd just finished cutting on the underside (hence the 4 hold down screws). This was the "cut out" toolpath in essence.My CNC Projects: https://www.youtube.com/imadethisoncnc
03-01-2017 #13
03-01-2017 #15
Details there, 4K RPM, 1250 mm/min, 3 flute 8mm roughing mill. DOC 10mm, WOC 1mm.Last edited by Chaz; 05-01-2017 at 06:45 PM.
And then failed attempt. Surprised by the endmill snapping. Expected more but I am severely limited by RPM. Sorry. the Youtube info isnt shown unless you watch it there but its at 1500mm/min.Last edited by Chaz; 05-01-2017 at 08:36 PM.
05-01-2017 #20
first move not clearing material
By kell in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 01-04-2016, 04:15 PM -
CNC Project - VESA Monitor Mounts using Fusion 360 Adaptive Clearing Toolpath
By Washout in forum Metalwork Project ShowcaseReplies: 8Last Post: 02-11-2015, 10:32 PM -
First go at Fusion 360 Adaptive Clearing
By Washout in forum Fusion 360Replies: 0Last Post: 15-10-2015, 07:52 PM
