As Clive says, nice to see cock ups as well as triumphs.....I like the way the sacrificial bed moves to save the cutter when the spindle overloads
03-01-2017 #2
03-01-2017 #3
To be honest I think that would have contributed to the stall slightly because if you watch carefully it starts moving around soon into the cut and because the cut was so aggressive was pulling material into the cutter increasing the step over.
When first watched saw that straight away and first thoughts where it had pulled into cutter but after checking i-machining can see it was bit aggressive but just for laughs think I'd try again with stiffer setup.Last edited by JAZZCNC; 03-01-2017 at 06:11 PM.
03-01-2017 #4My CNC Projects: https://www.youtube.com/imadethisoncnc
03-01-2017 #5
first move not clearing material
By kell in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 01-04-2016, 04:15 PM -
CNC Project - VESA Monitor Mounts using Fusion 360 Adaptive Clearing Toolpath
By Washout in forum Metalwork Project ShowcaseReplies: 8Last Post: 02-11-2015, 10:32 PM -
First go at Fusion 360 Adaptive Clearing
By Washout in forum Fusion 360Replies: 0Last Post: 15-10-2015, 07:52 PM
