And then failed attempt. Surprised by the endmill snapping. Expected more but I am severely limited by RPM. Sorry. the Youtube info isnt shown unless you watch it there but its at 1500mm/min.Last edited by Chaz; 05-01-2017 at 08:36 PM.
05-01-2017 #2
05-01-2017 #3
Its the same path as the previous cut. The first one was done a bit slower. The stock dimensions are less than what was programmed, that's why it cuts a bit of air but it does look like it 'plunged' but it did path is the same cut as the first vid (just reset the zero and went again).
06-01-2017 #4
But did you move the stock so it thinks in different place or possibly didn't zero Y axis exactly right because to me it looks like it's doing positional move and thinks stock edge is in different place to where actually is. The fact the tool path retract distance when moving is so close doesn't allow much room for error.!
05-01-2017 #5
I think I have another 8mm roughing mill. Will setup a toolpath that that goes around the square with constant contact and see how that works.
first move not clearing material
By kell in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 01-04-2016, 04:15 PM -
CNC Project - VESA Monitor Mounts using Fusion 360 Adaptive Clearing Toolpath
By Washout in forum Metalwork Project ShowcaseReplies: 8Last Post: 02-11-2015, 10:32 PM -
First go at Fusion 360 Adaptive Clearing
By Washout in forum Fusion 360Replies: 0Last Post: 15-10-2015, 07:52 PM
