Hi All,
Just as a way of update from the OP here are two related videos - one for Fusion 360 CAD/CAM and one for the entire cutting job, with successful adaptive clearing using 6 and 4mm 3 flute roughers @ 10 and 5mm DoC respectively:
Hopefully the more aggressive cutting has me off of the "cruelty to cutters" watch list ;)Last edited by Washout; 07-01-2017 at 01:22 PM.
My CNC Projects: https://www.youtube.com/imadethisoncnc
07-01-2017 #2
07-01-2017 #3
Thanks Chaz,
I need to add in some single flute cleanup passes for the scalloping the adaptive cutting leaves, but it came out nicely for what I need it for.My CNC Projects: https://www.youtube.com/imadethisoncnc
07-01-2017 #4
Looking good but when that really usefull guy shows up tell him the noise isn't the bed moving or hard/soft spots it's the tool rubbing because the Adaptive stepover is little aggressive for that portion of the Arc where it goes from Thin to Thick or vise versa. ( you'll notice it's always in corner or tighter Arcs)
I get the same noise with i-machining and it's why I don't go so aggresive on the stepover. Having more coolant will reduce the noise, mostly because lowers the rubbing affect, but lowering step over is best if doing it in lots of areas.
It's an horrible noise that scares the shite out you because like feels playing russian roulet with cutter.!!!Last edited by JAZZCNC; 07-01-2017 at 10:25 PM.
first move not clearing material
By kell in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 01-04-2016, 04:15 PM -
CNC Project - VESA Monitor Mounts using Fusion 360 Adaptive Clearing Toolpath
By Washout in forum Metalwork Project ShowcaseReplies: 8Last Post: 02-11-2015, 10:32 PM -
First go at Fusion 360 Adaptive Clearing
By Washout in forum Fusion 360Replies: 0Last Post: 15-10-2015, 07:52 PM
