    Thanks Chaz,
    I need to add in some single flute cleanup passes for the scalloping the adaptive cutting leaves, but it came out nicely for what I need it for.
    Looking good but when that really usefull guy shows up tell him the noise isn't the bed moving or hard/soft spots it's the tool rubbing because the Adaptive stepover is little aggressive for that portion of the Arc where it goes from Thin to Thick or vise versa. ( you'll notice it's always in corner or tighter Arcs)
    I get the same noise with i-machining and it's why I don't go so aggresive on the stepover. Having more coolant will reduce the noise, mostly because lowers the rubbing affect, but lowering step over is best if doing it in lots of areas.
    It's an horrible noise that scares the shite out you because like feels playing russian roulet with cutter.!!!
  1. first move not clearing material
    By kell in forum Artsoft Mach (3 & 4)
    Last Post: 01-04-2016, 04:15 PM
  2. Replies: 8
    Last Post: 02-11-2015, 10:32 PM
  3. First go at Fusion 360 Adaptive Clearing
    By Washout in forum Fusion 360
    Last Post: 15-10-2015, 07:52 PM
