    Quick release drawbar for Tormach style tools.
    The drawbar is accessible and can easily be pulled out by swinging the levers, as shown in the video.
    Edward
    Hi Edward,
    that is an amazingly clean conversion!
    https://emvioeng.com
    Thank you! So far everything is working well.
    The only problem I had with this quick tool change was that on one occasion the tool holder started to slip out as I cut with an 8mm endmill. The Bellevilles had been tighten by two full turns of the drawbar (after finger tightening) and it seems that the tool wasn't getting enough grip by the collet. So I increased the Belleville tightening to just over 3 turns of the drawbar, and now it seems to be gripping properly. These things always need a little fine tuning...
    Edward
    Hi Edward do you have a set of plans available as sx2.7 conversion kits are not available in UK mostly USA I have not seen any plans floating about on internet yet it would be wonderful if you could supply plans in pdf format or even better dfx if you can to help others
    Thanks Andrew
  1. Sieg X3 Conversion
    By Vikash in forum Milling Machines, Builds & Conversions
    Last Post: 04-01-2016, 05:18 PM
  2. CONVERSION: Need some help with a new SIEG SX2 Plus CNC Conversion
    By Onocyclone in forum Conversion Build Logs
    Last Post: 17-09-2014, 01:00 PM
  3. CONVERSION: Sieg X2 CNC Conversion
    By A11an in forum Conversion Build Logs
    Last Post: 16-01-2013, 06:06 PM
  4. CNCFusion Sieg X1 CNC Conversion Kit
    By rd84 in forum Gantry/Router Machines & Building
    Last Post: 13-07-2011, 03:38 PM
  5. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
