    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    Ive got one of the el cheapo units with the slop in the headstock. It works but not well. Will be looking to see if I can improve it over the coming days - Ive seen a vid of someone that turns a new headstock with better tolerances and replaces the unit with a somewhat marked improvement.
    Thanks for the responses so far. I'm not in any way, shape or form an engineer or even trained, I just buy these tools and figure out the rest for myself. As such I'm not clued up on what to look out for and what to avoid, which manufacturers are reputable and which are the same tat sold under different brands for wildly varying prices.
    A mill / drill was ideally what I wanted, but they come with a price tag. The Sieg SX2/2.7 in particular was what I had been looking for (2nd hand) but one never popped up. These things usually tend to go on sale on forums, and are sold within a day of being posted so it's difficult to catch them.
    After having recently received 40 faulty components which need seized steel inserts drilling out and replacing ASAP (they don't fit under the NuTool when clamped with a drill bit in the chuck, and I doubt it'd be up to it anyway) the matter has become more pressing so I'm probably going to have to settle for a straight out drill.
    I remember reading your thread a few months back routercnc, when I first thought about getting a proper drill.
    Sounds like 'this old tony' on YouTube. He upgraded a cheap drill press with a new quill (just for fun mainly). Not what the OP wants but good viewing anyway.
    Chaz's Avatar
    Thanks, ill go find it and see what was involved.
  6. The Following User Says Thank You to routercnc For This Useful Post:
  7. #6
    Chaz's Avatar
    Thanks. That frame and setup is almost identical to mine. My start buttons are on the side but its virtually identical.
  8. #7
    I would buy a mini mill instead for that money. An used one. And fashion some pillar and stand if such big clearance is needed. Or hunt for a serious industrial one from a scrap yard. It should be more than 150-200 from there. In fact thats exactly what i did/ the mini mill with a round column/ and could not be more happier.
    As mentioned it's exactly what I wanted, I know you can get them within budget but I never saw one, only those really cheap tacky looking Proxxon mills.
    Big clearance isn't needed, just more than the 165mm my current one has. Bench top is ideal, floor standing is ok. 280mm clearance should be more than enough.
    No floor space for a real mill, and to be honest it would be overkill for the usage it would get anyway. That said, when you have the tools, you always find something to use them for.
    I need to make a decision on this sooner rather than later, the Warco drill is currently odds on.
  1. VFD for drill press
    By Noplace in forum Motor Drivers & Controllers
    Last Post: 31-03-2016, 12:09 PM
  2. WANTED: Drill press
    By D-man in forum Items Wanted
    Last Post: 30-08-2013, 07:45 AM
  3. RFQ: Press cost question ?
    By Fivetide in forum Projects, Jobs & Requests
    Last Post: 01-12-2012, 08:26 AM
  4. Replies: 0
    Last Post: 04-03-2010, 05:36 PM
