ID:	20212Click image for larger version.
    As per the title, the plan is to convert an AMAT25LV. It seems a well trodden path so am hoping with the info available and some nudging back on track where required from you guys all should be well. I do have some questions at the bottom so would really appreciate your comments;
    p
    For info, I'll be machining aluminium perhaps 80% of the time, with occasional steel parts thrown in. Mostly car components for various petrolhead projects. I can always do some of the serious hogging out on the Bridgeport if it becomes a better option.
    p
    Things I've done/bought so far....
    p
    Electronics
    • NEMA23 4nm motors for X & Y axis
    • NEMA34 8nm motor for Z axis (I plan to add power drawbar etc and had read that a bigger motor would be a good idea for the Z axis
    • Digital steppers, 5.6A for NEMA23 and 7.2A for NEMA34
    • CP0-10V 4 axis breakout board. Only planning on using 3 Axis initially but wanted to leave option for 4th if it ever became desirable
    • 48v power supply for drivers/motors
    • 24v power supply for breakout board
    • I've added an additional 4 relays and seperate 5v power supply to control box for future upgrades
    p
    At this stage I've pretty much finished up the machine control box. (you'll note from the pics that even if I cant afford a Tormach, I can at least have a fancy Tormach inspired logo? lol)
    p
    The current thing I'm working on is an enclosure. I want a really solid stand (I had the RF30 on a flimsy stand and it rattled like a good un). The plan is that whatever I make will also be bolted to wall/floor. I also want something enclosed to keep the chips down. I've pretty much made the base and am starting to fiddle with the tray and enclosure next.
    The mill should arrive in a couple of weeks. I went with Amadeal as the price seemed fair and also they had an R8 version in stock. All of my Bridgeport tooling is R8 and whilst I'd want at some point to dedicate tooling to the CNC mill, seems to make sense to keep options open.
    p
    I do have some questions. Mostly thoughts I've got based around what I've read others doing;
    1. I've read that bracing the Z column helps rigidity a lot. It sounds like common sense but has anyone tried it and able to comment or advise on what works best. I've put a box section upright on the rear of the base to give me something to brace to (or could go to wall if necessary)
    2. Is it worth upgrading the spindle bearings to angular contact (see next question)
    3. Is it worth increasing the spindle RPM? Playing with a feed/speed programme 4,000rpm seems a useful speed to aim for when I'm machining aluminium?
    4. If so is it simply a case of swapping out pulleys or will the motor struggle? It's sold with a 1kw brushless DC motor.
    5. I was planning initially to run mist coolant although I'll build the enclosure with flood in mind. I understand that chip evacuation is my primary goal with lubrication a second and cooling a third priority. I'll read through other posts but any major objections to mist?
    6. I'm a little baffled by the pro's and cons of mechanical limit v proximity sensors? I have some limit switches but if its the right way to go, then happy to ditch them and switch to proximity, or am I getting this back to front and I need both??
    7. Can anyone confirm how I should work out the amp setting for the drivers (am I being thick again?!)
    Appreciate any thoughts
    Welcome to the forum Lloyd. My comments would be up the volts on the drives if you can 68V is a good number with AM882 or EM806 drives and it definitely needs to be higher on the nema34.
    I take it you are using ball screws.
    I have done the conversion on the WM18 and used 23s with belt reduction all round and it runs fine.
    Good luck with the build
    Thanks Clive
    I'm using drivers from CNC4YOU.
    5.6A, 50V CWD556 for the 23's
    7.2A, 80VDC or 60VAC CWD872 for the 34.
    I guess that means my best bet would be to keep the 48v supply for the 23's and add a 68V for the NEMA34 then?
    Quote Originally Posted by Lloyd Barnes View Post
    Thanks Clive
    That's the problem that has been highlighted many times on the forum with buying kits.
    Personally I would change the drives and built a toroidal transformer type PS.
    No kits here Clive, I prefer to choose parts/screw things up myself
    Go for 2:1 reduction on the head and you won't need gas struts etc.
    John S -
    Hi lloyd , can you tell me where did you get all the motor mounts etc.. from ?
    Quote Originally Posted by Tymogoral View Post
    Hi fella
    I made them myself as I also have a manual Bridgeport in the garage (cant help myself if I see a decent machine! lol)
    I modelled them in SolidEdge first. You are welcome to the drawings if they help.
    Interested to know how you wired the spindle speed to the controller or did you leave it manual on the pot?
    I've got a board that has a 0-10v + gnd output and on/off relay built into it for spindle control.
    Not bothered about on/off or direction just which connections to use for the speed outputs.
    Thanks.
    Daz.
    Quote Originally Posted by Kered View Post
    Going back to your enclose, you don't happen to have any plans available for share, even a scratch drawing with basic dimentions would be fine, much better than doing things on the fly and having to change something later(like I usually do)
    cheers
    Derek
    Be interested in this as well. Also interested of the user-experience if the enclosure gets in the way or not - or rather, if it's ultimately better with an enclosure than without - I'm tight on space but sick of pebble-dashing the delicates with man glitter whenever I use the mill.
    @Daz1976 checkout the videos by franco, he fried his mainboard looking and testing his to find the motor control, he got it done eventually
    Thats as clumsy as me - watching a BLDC controller go pop quite enthusiastically when scoping it. That a 800W servo and controller was cheaper than the replacement board made for an easy solution.
  1. Looking into converting my Mill to CNC
    By T0rnado69 in forum Emco Milling Machines
    Last Post: 14-02-2019, 12:46 AM
  2. Hello everyone need help converting a emco f1
    By Ecu-master in forum Emco Milling Machines
    Last Post: 30-03-2014, 08:42 PM
  3. Hi help converting emco f1
    By Ecu-master in forum Milling Machines, Builds & Conversions
    Last Post: 30-03-2014, 12:24 PM
  4. converting pdf to cam?
    By motoxy in forum Computer Software
    Last Post: 28-02-2014, 08:11 AM
  5. Converting sketchup to dxf
    By motoxy in forum Sketchup
    Last Post: 08-07-2012, 12:04 PM
