Thread: Converting an AMAT25LV
14-02-2017 #20
Quick questions folks
p
Just modelling up the Z motor mount plate to convert over to a 2:1 belt drive. Are you guys just running a pulley on the unsupported shaft of the stepper motor or are you adding some kind of additional bearing support? I'm conscious the belt is going to need to be pretty tight to avoid backlash, but worried about overcooking it and putting a tonne of side load on the motor shaft.
p
What have you chaps done?
Looking into converting my Mill to CNC
By T0rnado69 in forum Emco Milling MachinesReplies: 16Last Post: 14-02-2019, 12:46 AM -
Hello everyone need help converting a emco f1
By Ecu-master in forum Emco Milling MachinesReplies: 3Last Post: 30-03-2014, 08:42 PM -
Hi help converting emco f1
By Ecu-master in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 30-03-2014, 12:24 PM -
converting pdf to cam?
By motoxy in forum Computer SoftwareReplies: 7Last Post: 28-02-2014, 08:11 AM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM
