Thread: CNC 4th Axis at work
31-07-2009 #11
So the router tables being built here and run with mach3 are all 2.5d ?
31-07-2009 #12
No they can be either.
It all depends on the code they are fed.
Mach is capable of 3D linear moves.
.John S -
31-07-2009 #13
So the trick is generating the code. .. ands that's what cadcam does?
31-07-2009 #14
I have some g code experience as i have an old Ikegai lathe with a fanuc 6t control on. Also used a mini mill but only as a production machine. Never got the chance to play with it and its now gone.
Would like to build a plasma / router combo 4' x 4' . Have been watching Tribbles link with great interest. Would that convert to plasma ?
I have a decent work shop with a bridgeport vertical mill ( manual) TIG and MIG so have got the gear. Pretty good with PC's but limited electrical experience. Also know my way around solid works.
I guess i'm just trying to convince myself to "have a go"!
Al
31-07-2009 #15
31-07-2009 #16
You can't have a decent workshop if you have a Bridgeport :whistling:
.John S -
Work hold down
By gorbo in forum Woodwork DiscussionReplies: 16Last Post: 27-03-2020, 09:15 AM -
I am looking for work as cnc operator.
By krystiankania in forum Opportunities Available & SoughtReplies: 0Last Post: 13-02-2014, 03:55 PM -
RFQ: I am looking for work as cnc operator.
By krystiankania in forum Projects, Jobs & RequestsReplies: 0Last Post: 13-02-2014, 03:48 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
