  1. #24
    Edward's Avatar
    Lives in London, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 114. Received thanks 3 times, giving thanks to others 0 times.
    In my case, a Sieg2.7 probably about the same size as yours I think, I machined the top of the ballnut flange a little , about 2.5mm, so I could still use the two top side holes of the flange, and this allowed the ballnut to fit under the table, so the table didn't need any machining at all. Then I had to machine the end side of the saddle (that's where the ballnut housing goes in my machine, I think yours may be in a different place) I just ground a little crescent concavity for the bottom of the ballnut to sit on.
    After doing that, the ballscrew had a clearance of about 2mm from the saddle, but unfortunatelly at the other end of the saddle, the clearance gradually diminished as the casting was irregular, not level. So I just had to groove that end a little to allow the ballscrew to clear by about 1 mm.
    When fitting the end plates, I found that the existing threads at both ends of the table were not tapped perpendicular, they were clearly askew, you do find surprises here and there, but you somehow work around them:)
    Although I feel your excitement, I think there is no point in planning anything too seriously until you actually get the mill, then you will be confronted by the real problems.
    For cutting the top end of the ballnut flange I used a little dremel cutting disc, ( took 5 minutes) but I think if I had had a proper grinder, it would've been done in no time.
    I too worried about the metal stress, but hopefully I didn't grind too much metal to cause any trouble.
    Edward
  2. The Following User Says Thank You to Edward For This Useful Post:
  1. Waterproof CNC Router Cutting bed
    By mondrota in forum Machine Discussion
    Last Post: 03-06-2019, 10:12 AM
  2. CNC Router V1.0 (For Cutting Multiple Materials)
    By biketrialsdave in forum Gantry/Router Machines & Building
    Last Post: 05-08-2017, 03:37 PM
  3. Cutting metal shapes
    By jmac80 in forum Metalwork Discussion
    Last Post: 27-11-2013, 10:32 PM
  4. aluminium profile for cutting bed of router
  5. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
