    If it has ATC a pause can be introduced before tool change, spindle stop, brush attachment removed by hand, tool change, attachment on, spindle on and follow.
    But in real life the people that have tool change and use the shoe, remove the stripes or change to shorter attachment so tool change can be done. You know, some dust on table but not in the air, which is more important
    That's defeats the whole point of ATC. The very reason for ATC is so it can be left unattended to get on with the job, if you have to baby sit the vacuum it's a waste of time having the ATC. Nobody who fits an ATC and wants to use it to it's full potential would accept your suggestion.
    Those who have a need and can afford an ATC spindle will most probably have a clean Z-axis setup or at least the abilty to modifiy the Z-axis. A retractable or movable dust shoe is a MUST for an ATC to function correctly if it uses a typical Fork or carosel type slide in tool rack.
    Edit: It wouldn't be a massive change to stick some wings on it, open up the spindle hole a little and use the setup as I made here. The customer would just need to make brackets for the pneumatic actuators which can fasten either to the front plate or like I did here on the spindle mount itself so comes off as a unit with spindle mount.
    I agree and am more than happy to design and fabricate the setup above for a paying customer, obviously the design time for such a specific job has to be on top of the dust shoe price
    Ok, but your missing my point.! . . . . The Standard router market is flooded with dust shoes. . . . The ATC router market isn't.!
  5. #4
    I see what you are saying. Will start to design something around HSD Spindle and round spindle like yours. Is yours 100mm body?
    Yes 100mm.
  1. Diy dust shoe dust strip bristles
    By charlieuk in forum Dust Extraction & Collection
    Last Post: 18-06-2019, 10:47 AM
  2. Dust shoe
    By shedman in forum Machine Discussion
    Last Post: 01-01-2016, 09:25 PM
  3. Dust shoe bristles
    By charlieuk in forum Gantry/Router Machines & Building
    Last Post: 06-11-2014, 03:45 PM
  4. Dust Shoe Deisgn
    By m.marino in forum Open Source Designs & Plans
    Last Post: 01-08-2013, 12:19 PM
  5. What size water hose for 2kw spindle?
    By motoxy in forum Generic Chinese Spindles
    Last Post: 05-08-2012, 05:30 PM
