Continuing with my conversion to the CSlabs csmio ips controller and mach3 I was trying to get the vfd connected up this afternoon.
Finished the wiring and powered up the panel then opened up mach3 to do the configuration.
Tried to open the cslabs config plugin and I'm getting the following errors when opening the plugin and then trying to save any changes.
Name:	config plugin apply and save.png
ID:	20251Click image for larger version.
Name:	select config plugin.png
ID:	20250Click image for larger version.
Name:	config plugin apply and save1.png
Also now when pressing reset on mach3 I'm getting this error now as well "Spindle drive fault. Machine stopped."
I disconnected the input I had from the vfd fault relay, even though I had not yet setup the input for it yet, to see if it made a difference but it didn't.
Can anyone help?
