Thread: mach3 csmio ips errors
07-01-2017 #3
Strange happenings there mate which I've never seen before. Suggest you Flash the Firmware and do full Re-install of Mach3 and the Plug-in.
Make sure your running as Admin.
The number for filter is 1, don't go anyhigher as it slows the input reaction times down. It works like mach3 noise filter. Never had to use it yet thou so can't see why you would unless you have a wiring issue some where.?
Regards the Spindle Fault Output then hard to say without seeing how you wired it. What VFD and are you using Relay output for fault or Digital output in which case then both VFD and IP-S will need to share the same Ground Ref.
CSMIO-IP/S Driving Relays directly
By cropwell in forum CS-Lab (CSMIO)Replies: 10Last Post: 02-01-2017, 01:40 AM -
Axis scaling errors - is this just to be expected with C7 screws?
By GND in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 23-11-2016, 11:19 PM -
Mach3 oem buttons with CSMIO-IP/S
By Web Goblin in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 07-11-2016, 07:14 AM -
Motorcalc spreadsheet errors
By jimbo_cnc in forum General DiscussionReplies: 7Last Post: 10-03-2015, 07:02 PM -
ES-D1008 + CSMIO/IP-S wiring
By Matt81 in forum CS-Lab (CSMIO)Replies: 3Last Post: 03-05-2014, 10:56 PM
