Thanks Nick. So to confirm, I would just connect the current mains plug wires to the "motor terminal" end of the switch (as these go to the starter relay) and wire a mains supply to the other end and supply air pressure to it?
Yes its a standard 13A plug, would the cheaper unit rated at 15A (http://www.ebay.co.uk/itm/New-Single...kAAOSwLqFV9dJb) still be suitable? Thanks.
07-01-2017 #2
That should work, I usually go for switching kit to handle more power as the contacts will usually last much longer if not loaded anywhere near their max rating,
The Following User Says Thank You to magicniner For This Useful Post:
Proximity limit switch problems
By davrich in forum General ElectronicsReplies: 16Last Post: 12-03-2018, 01:58 PM -
Limit switch problems
By Neeps in forum General ElectronicsReplies: 9Last Post: 11-09-2016, 12:02 AM -
Optimum air pressure for the laser air assist?
By Want2build1 in forum Laser Machines & BuildingReplies: 0Last Post: 13-05-2014, 09:50 AM -
Why does it happen when you are under pressure ?
By cropwell in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-12-2013, 11:12 PM -
Bottle jack with pressure guage port in the UK?
By Inquisitor in forum Marketplace DiscussionReplies: 12Last Post: 31-12-2012, 06:50 PM
