hi, what do you mean. the wiring goes from the breakout board to the motor driver and then from the driver to the motor. what motor power supply is there needed and how does that wire into the system. michael
09-01-2017 #2
The drives should be powered by a separate DC power supply, typically around 48V or so. I'd need to see your drives or get a model # for more info.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
09-01-2017 #4
thanks Clive, what voltage for the driver, and do I still need a separate 5 volt input to the breakout board, or will the usb be ok.
09-01-2017 #6
hi, the microstep driver is a FMD2740C . apart from adding a power supply to it is there any other wiring that needs to be put in place. also how do you find the pin numbers from the card. thanks
Ok they are 50V drives so you will need about 36 - 45 volt DC power supply.
Also the dip switches you have them set at 0.5A which is far to low.. So set sw5 to on sw6 to off sw7 to on that will give you about 3 A
Are you using mach3 or what?
Edit I see it runs off usbcnc so I think this is the manual http://www.variometrum.com/PDF/USBCNC_csatolo_ENG.pdfLast edited by Clive S; 09-01-2017 at 06:03 PM. Reason: added text
09-01-2017 #8
Hi.on the motor driver there is a power in marked V+ which matches a terminal on the 36v power supply which came with the kit.however the second driver inlet is marked G for ground.the only G terminal on the power supply is on the inlet 240v side.the only free terminal is marked V-. So do I wire the driver G terminal to the G terminal on the power supply or to the free V- terminal. There are two leads on the driver,I take it the green one is power ok and the red one bad news.
09-01-2017 #9
the -ve with the blue wire connected on the power supply goes to the GND on the driver next to Vin+
anyone using an e-cut 1 mhz usb breakout board
By nobby in forum Control Hardware & SystemsReplies: 10Last Post: 22-10-2018, 11:50 PM -
help needed with breakout board
By terry1956 in forum Motor Drivers & ControllersReplies: 22Last Post: 07-09-2016, 07:58 PM -
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
FOR SALE: PMDX-122 Breakout board
By IN-WondeR in forum Items For SaleReplies: 0Last Post: 14-12-2011, 04:05 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM
