11-01-2017 #11
11-01-2017 #12
OK - so extending the shielding over the plastic components that are otherwise not protected. I can see your point now!
Graeme
11-01-2017 #13
Banana plugs - I kind of passed on these as they are un-latched and thus vibration sensitive, but hadn't thought of detaching from the plate end rather than the control box end. Mmmm, more thoughts to go into the melting pot.....
Graeme
11-01-2017 #14And ugly and not good with coolant etcTape is very easy to use. And fast...Clive
11-01-2017 #15
My touchplate plugs into a small plastic box bolted to the frame in an easy-to-reach but out of harm's way position. That's wired back to the control box where it connects with a GX16 captive connector. The box has a 3.5mm jack socket where the touchplate wire plugs in (with matching 3.5mm plug, obviously). Quick and easy to connect, reasonably vibration-proof. Wouldn't use jack plug for, say, limit switches but for something regularly connected/disconnected, seems ok. Very easy to check connection just by touching plate to anything earthed and watching Mach3 screen "led".
13-01-2017 #16
Which circular connector for spindle
By ROBCNCAU in forum Spindles & Drive MotorsReplies: 7Last Post: 19-06-2016, 09:20 AM -
Connector for THC ?
By Davek0974 in forum Plasma Table MachinesReplies: 0Last Post: 13-06-2014, 02:51 PM -
Digitizing probes practicality
By dudz in forum Probing, Digitizing & ScaningReplies: 2Last Post: 04-06-2013, 03:31 PM -
Spindle probes for centering
By maritimesbob in forum Probing, Digitizing & ScaningReplies: 4Last Post: 02-09-2012, 11:22 PM -
Cable + Connector issues
By tom3d in forum General ElectronicsReplies: 0Last Post: 09-01-2012, 07:56 PM
