10-01-2017 #1https://emvioeng.com
10-01-2017 #2
I'm using XLR 4-pin for motor connections. Signal connections (limit switches, e-stop, touch plate, etc) use GX16, bought cheap from Aliexpress. That's (I believe) the same connector that the usual air- and water-cooled spindles use with a screwed locking ring for security. Just hold them over a box or tray when you try to refit the fiddly little screw on the side...
11-01-2017 #3
11-01-2017 #4
Thanks for the feedback, guys - some good suggestions there!
From this small sample it seems like there's no single solution, and that hardwiring is often chosen. I can certainly see why that might be a good approach. I suppose it depends on the circumstances.
In my case I am keen to have my touch plate detachable, but obviously there is no room for this connection to be unreliable, else cutter breakages will occur! Hence a good quality latching connector, if you have to use one at all, is essential. I now have a couple of options to investigate further!
Just curious, Boyan - how do you deploy your conductive tape? Would you mind elaborating?
Graeme
11-01-2017 #5I don't see any reason to do this, just what is the pointhow do you deploy your conductive tape? Would you mind elaborating?
11-01-2017 #6
11-01-2017 #7
Thanks Boyan - so essentially shielding?
11-01-2017 #8
Which circular connector for spindle
By ROBCNCAU in forum Spindles & Drive MotorsReplies: 7Last Post: 19-06-2016, 09:20 AM -
Connector for THC ?
By Davek0974 in forum Plasma Table MachinesReplies: 0Last Post: 13-06-2014, 02:51 PM -
Digitizing probes practicality
By dudz in forum Probing, Digitizing & ScaningReplies: 2Last Post: 04-06-2013, 03:31 PM -
Spindle probes for centering
By maritimesbob in forum Probing, Digitizing & ScaningReplies: 4Last Post: 02-09-2012, 11:22 PM -
Cable + Connector issues
By tom3d in forum General ElectronicsReplies: 0Last Post: 09-01-2012, 07:56 PM
