11-01-2017 #11
Thanks a lot! That's great news as I do have rolled ballscrews...
I knew if asked long enough someone would give me the answer I wanted!
Also my whack idea about the rotary table as screw cutting lathe ain't gonna work as the 2MT small end in the table is smaller than 16mm...
So carefully by hand with plenty of lube it is... sounds familiar!Last edited by noyloj; 11-01-2017 at 11:45 PM.
11-01-2017 #12I knew if asked long enough someone would give me the answer I wanted!..Clive
11-01-2017 #13
12-01-2017 #14
Post it to me with the nut you want to use and I'll cut the thread on my lathe for the price of return postage.
Edit: Sorry I'm retracting that offer - I don't think this will help you as much as it might at first appear.
John S hit the nail on the head with "They can be screwcut with tipped tooling but I wouldn't fancy my chances with a die.".Last edited by Jonathan; 12-01-2017 at 12:31 AM.
The Following User Says Thank You to Jonathan For This Useful Post:
12-01-2017 #15
Because John S has done it hundreds of times with his own compact design for mounting the motor, bearing, nut and coupling.
Patented that is as well.
No sticking the motor on two plates and 4 pillars. Its a CNC machine not a fcuking clock.Last edited by John S; 12-01-2017 at 12:16 AM.
John S -
12-01-2017 #16https://emvioeng.com
12-01-2017 #17
The Following User Says Thank You to njhussey For This Useful Post:
12-01-2017 #18
Yes, that is a thing of beauty! I was thinking of a couple of bits of machined 4" x 2" angle ally machined up to form a square pr possibly welding up a few plates into a box kinda like the Damon CNC solution... Buerk! Clumsy in comparison but hopefully enough to get me to a position where I can CNC machine a neater solution...
12-01-2017 #19
22-02-2017 #20
Depends how good you are.
Material is not a problem it is not "superhard", it peeled and rolled thread, typically St 52 , surface is hard due plastic deformation
Core is relatively soft. the best method would be to use the lathe, but it shall not be a problem to do it manually presuming you will use proper oil and non-chinese die ...
regardsLast edited by fifa; 22-02-2017 at 10:10 PM.
There are currently 12 users browsing this thread. (0 members and 12 guests)
I need Ballscrew end machined....what do I tell the Chinese bloke doing the work?
By HankMcSpank in forum General DiscussionReplies: 10Last Post: 23-02-2017, 07:24 PM -
Thread cutting on Solidcam
By eamo1978 in forum SolidworksReplies: 0Last Post: 27-06-2014, 09:12 AM -
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
Multi thread cutting
By cropwell in forum Metalwork DiscussionReplies: 12Last Post: 03-10-2013, 10:32 PM -
Not Just another Boxford tcl 125 thread....
By cooliced in forum Boxford LathesReplies: 135Last Post: 18-08-2011, 10:15 PM
