    Hopefully that title got your attention...
    Well I bought a low profile drill vice for use on my Novamill (due to low Z travel) as it seemed one of the more compact machine vices without the very high price tag.
    It arrived, and is meant to have a milled and ground base, but when I put it on my table, or any table for that matter it rocks from side to side as pressure is applied to different bits of the vice.
    I can push one corner and it rocks that way, then press the other corner and it rocks that way - its not massive, maybe a few mm - but it makes it nearly useless.
    Is that a normal feature of these types of vices?
    I ask as I complained and the supplier contacted the manufacture (I wont name at the moment, but not a small name) and then sent me one direct - but when it arrived it too rocks (though not as much)
    So the question, is it normal to have a wobbly bottom?
    Send them both back. The bottom of the vice must be flat. In some cases precision vices are hand scraped to acheive this.
    Is the bottom is wobbly, I would hate to think what the surface between the jaws is like.
    You sure you didn't buy a drill press vice?
    https://emvioeng.com
    Even my drill press vices are nice and flat underneath, send 'em back!
    A good milling vice is definitely one of those bits of equipment where the money is well spent and a less than good one will consistently affect work unless it's shortcomings are precisely identified and compensated for,
    - Nick
    Interesting - thanks guys I will call them.
    Ref the vice, the reason I dont want to drop 500+ on one is I have such little Z height I wont be using for most jobs, as I plan on using alu fixture plates for most of the stuff (as I will be doing very small batches) so it sucks to drop so much on something that is there just for the odd adhoc job.
    Yes its a drill press vice - wasn't aware that made a difference? Just wanted something low profile for a decent ££ - imagined it would at least have a flat bottom
    Quote Originally Posted by Dangle_kt View Post
    I seem to remember one of the home machining books by the likes of Harold Hall or similar had a way of fixing the drillpress vises for light milling.
    As with most drill press related items they are only meant to take forces in one direction. have a look at low profile milling vices on googles. You do not need to go to the expense of 500.
    Thanks Komatias, I didn't know that... so the X and Y motion of the mill wont agree with the drill press vice? Thats interesting.
    So much to learn :D
    As you have a low Z clearance, you might consider a two part milling vice. Arc do one but it is probably too big. Chronos also have the Vertex ones, which are smaller.
    Someone on here (routercnc I think) linked to a low profile vise that they use...the likes of rdgtools, arceurotrade etc. all stock them I believe...
    Neil...
    Build log...here
    little video I made of the issue as it explains it better than I can
    https://youtu.be/iIlEiHpCyX0
    Lives in Plymouth, United Kingdom. Last Activity: 7 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    Could, I suppose, bolt it down inverted to parallels on the router bed, using the vice jaws machined surface on the parallels. Then skim the bottom. Pound to a penny, though, that the casting warped after machining and both bottom and "vice jaw face" are similarly distorted.
  1. v bit flat bottom
    By universally in forum Tool & Tooling Technology
    Last Post: 01-10-2015, 10:25 PM
  2. 1st time setting up.. whats normal..
    By Marlin in forum Motor Drivers & Controllers
    Last Post: 01-09-2014, 04:53 PM
  4. Milling vice, general milling vice or tool vice?
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 15-12-2012, 11:15 PM
  5. Looks like the normal first page has gone awry.... or is it my PC?
    By WandrinAndy in forum General Discussion
    Last Post: 03-10-2012, 08:05 PM
