    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    I take it nobody has noticed the dual low speed motor (for the feed?) makes no mention of voltage?
    And I'd guess it will be designed for 380V only.
    I just read the motor plate which states Delta 240 Star 415 on the main plate
    Hi m_c
    Thank you for your reply
    Yes, you are spot on the motor you refer to is for the feed and I like you bet is it 380V is that a spanner in the works! I thought I was getting off light!
    Many thanks
    Steve
    And it's not just a motor, it's a gear motor so no easy swapouts :-(
  5. #15
    I had spotted the other motor but with the correct vfd it could power both, that is why I suggested him to contact the company and speak with them I have answered sues134e in the past and realised he was not hot on electrics. Np disrespect to him.
  6. #16
    Might be worth having a look under the plate over the connections on geared motor to see if delta/star is possible. While it doesn't say it's dual-voltage, it doesn't appear to say that is single-voltage either. Can you post a pic?
  7. The Following User Says Thank You to Neale For This Useful Post:
  8. #17
    Hi Neale going to get a photo a little later mate with a bit of luck just have to move the machine to get in the gap to take a picture. That was a good idea we will see what the picture brings about! many thanks Steve
  9. #18
    Hi Neale and you guys that have helped and thanks for that. Here after a lot of swearing, poor photos and ripped shirt we have a photo of the plate from the geared motor I had to take it off, it was in a pig of a position!
  10. #19
    As I suspected, it's a dual speed motor, which are usually only designed for a single voltage.
    IIRC it'll have 9 wires in the terminal box, which depending on how they're connected, set the speed.
    Don't mistake the number of wires as being a way of changing the voltage like a standard 3 phase motor.
  11. The Following User Says Thank You to m_c For This Useful Post:
  12. #20
    Well m_c thank you for your reply and the info. I will not get to the wires until I get the machines off the deck or stripped down. I take the caution you say on board but it must be I guess why the firm said a VFD was no good. I will contact them again just on the off chance! Many thanks Steve
  1. formula for capacitor on 3 phase motor
    By dudz in forum General Electronics
    Last Post: 13-11-2015, 05:37 PM
  2. Myford 7, 3 phase motor other CNC questions.
    By Jconway651 in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 28-01-2015, 10:33 AM
  3. Replies: 2
  4. single and 3 phase motor sizing and mounting ?
    By Musht in forum General Electronics
    Last Post: 27-10-2013, 09:58 PM
  5. Panasonic 3 phase driver running on 1 phase?
    By gavztheouch in forum Motor Drivers & Controllers
    Last Post: 10-05-2012, 11:21 PM
