19-01-2017 #21
OK guys
I have an update I am told I need the following
Well the L5-203 will power the first motor and these cost £300+£60 for the ON/OFF, REV/FWD and SPEED POD and the second motor will need the D2-401 and these cost £300 and a POD with REV/OFF/FWD and SPEED is £50 if needed,
http://www.ebay.co.uk/itm/1521761339...%3AMEBIDX%3AIT
I have found a link for one of the items
Just wanted to update you guys as you have been good enough to help me here!
Steve
19-01-2017 #22
You may find it cheaper to get the motor rewound (just google "motor rewinding" for somewhere local) and use a more standard VFD. e.g. one of the common Chinese brand: http://www.ebay.co.uk/itm/2-2KW-3HP-...UAAOSwUKxYeYVQ
Or something second hand from a good brand (e.g. Siemens, ABB, Parker). Unless you are unlucky, the Chinese one will last a long time as you're running somewhat less that its power rating.
The VFDs which accept 240V and output 415V seem expensive for what they are. It's tempting to copy the idea ... or just use a 415V VFD from a suitable DC supply (sometimes works).Last edited by Jonathan; 19-01-2017 at 01:53 PM.
formula for capacitor on 3 phase motor
By dudz in forum General ElectronicsReplies: 10Last Post: 13-11-2015, 05:37 PM -
Myford 7, 3 phase motor other CNC questions.
By Jconway651 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 23Last Post: 28-01-2015, 10:33 AM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
single and 3 phase motor sizing and mounting ?
By Musht in forum General ElectronicsReplies: 5Last Post: 27-10-2013, 09:58 PM -
Panasonic 3 phase driver running on 1 phase?
By gavztheouch in forum Motor Drivers & ControllersReplies: 2Last Post: 10-05-2012, 11:21 PM
