Thread: Huanyang VFD and spindle problem
Thanks for your answers!
@JAZZCNC maybe if you take some English ales with you ;)
I just begin to check the circuit. By now, tracks are surprisingly good, but there is some strange connections... I will continue to test the circuit.
I checked the part in china but you're right it will be difficult to replace it with the same model.
It would be awesome if you could advice me :)
A good shop in Switzerland is Distrelec. I've searched for some replacement parts (http://www.distrelec.ch/search?q=iGB...=4&pageSize=10) and I think about this one maybe: http://www.distrelec.ch/fr/igbt-to-2...=50&simi=97.47
Should I replace all IGBT or only the broken one ?
Thanks you, all for your help.
23-01-2017 #2
The IGBT you linked to is TO220 package, but the original is TO247 so you should look for that instead. Also the voltage rating (surprisingly) is 1200V, so I would get the same unless replacing all of them. I would replace both in the same 'leg' on the inverter - so 2 out of 6, unless more seem to be fried.
23-01-2017 #3
Ok, this model is a better choice ? http://www.distrelec.ch/fr/igbt-to-2...=50&simi=96.69
23-01-2017 #4
That's better. Next check that the turn on/turn off delay times in the datasheet are no greater than those of the original. Same for the total gate charge (Qg). This is for compatibility with the programmed dead time and gate drive. If those specifications are met you can be reasonably confident that it's suitable. You could go into more detail (e.g. compare the Vds vs Ids), but it's not really worth it for a cheap product and you would need to identify more components in the circuit to be sure.
Edit: Also, in order of preference for brands I would go with for IGBTs are Infineon, IR, ST / ON Semi & others. But this is pretty subjective.
[P.S. I'm trying to demonstrate how to choose - not just give you a link. For reference, I've found some in England for around 3 CHF.]Last edited by Jonathan; 23-01-2017 at 08:34 PM.
25-01-2017 #5
I appreciate your help, I'm reading more about these IGBT to have a better understanding of these.
Is it better to have the nearest value as possible or just lower than the original? I think the nearest, am I right?
There is different type of "TO247" like TO-247-3, is it the same?
So, I found some of them, the cheapest one I found with corresponding datasheet: 1,2,3
I would go with the first one if you think it's a good choice or I'm missing something ?
25-01-2017 #6
I'm interested to see if you will be able to repair your vfd as I also have a similar one with the same problem, but I have some more damage on the PCB. My IGBTs are the Fairchild FGA25N120, possibly the more expensive ones but not sure what's the difference between the two. Anyway I wanted to let you know that on exactly the same PCB, the Chinese fitted these IBGTs in my unit. No sure if it helps..
26-01-2017 #7
It depends on the parameter. For a new design, you want the lowest values that affect the conduction and switching losses, so the forward voltage and switching time (related to gate charge) respectively. However when replacing a part you need to consider that the engineer will have matched the gate drive circuit to the particular IGBT, one would hope at least. Switching faster leads to more emi, so it's common to intentionally switch the devices more slowly (by increasing the gate series resistor) to reduce the emi to meet a specification. You could look at what gate resistors you have, versus the datasheet values - but bear in mind the datasheet isn't definitive. At best it's a good guideline, at worst it's a marketing document designed to make you buy the part.
This sort of thing matters more with bigger devices, like these 900 Amp ones I've been playing with lately:
I think the -3 is just designating that the part has three pins. One important thing to check is if the package of the ones you have has metal on the back, or is all plastic? If plastic, then you should either get the same or add insulation to the new ones (bit awkward).
I think it's OK - the forward voltage is a bit higher so it will heat up more, but the current used with these spindles tends to be a lot less than the VFD rating so you will get away with it. If it breaks again you know what to do...
30-03-2017 #8
Hi everyone,
Good news!
After replacing two diodes, one resistance and two IGBT, the VFD works perfectly. I hope this will last...
Thanks for your help!!
Very happy to see it work again!
06-09-2017 #9
07-09-2017 #10
Weird problem - stepped/staged deceleration on Huanyang 2.2kw Spindle
By glynster in forum Spindles & Drive MotorsReplies: 0Last Post: 25-01-2016, 01:39 PM -
Problem with Spindle not spinning
By Noplace in forum Spindles & Drive MotorsReplies: 4Last Post: 22-01-2016, 02:40 PM -
CONVERSION: Emco F1-p Mill Mach3 convention, Spindle motor problem
By andre13442 in forum Conversion Build LogsReplies: 7Last Post: 14-01-2016, 12:14 PM -
Huanyang hy02d223b frequence convertor problem
By frans cop in forum Motor Drivers & ControllersReplies: 3Last Post: 14-07-2015, 10:33 AM -
CNC spindle control VFD problem
By djc in forum Motor Drivers & ControllersReplies: 1Last Post: 13-09-2009, 09:26 PM
