    I appreciate your help, I'm reading more about these IGBT to have a better understanding of these.
    Is it better to have the nearest value as possible or just lower than the original? I think the nearest, am I right?
    There is different type of "TO247" like TO-247-3, is it the same?
    So, I found some of them, the cheapest one I found with corresponding datasheet: 1,2,3
    I would go with the first one if you think it's a good choice or I'm missing something ?
    I'm interested to see if you will be able to repair your vfd as I also have a similar one with the same problem, but I have some more damage on the PCB. My IGBTs are the Fairchild FGA25N120, possibly the more expensive ones but not sure what's the difference between the two. Anyway I wanted to let you know that on exactly the same PCB, the Chinese fitted these IBGTs in my unit. No sure if it helps..
    Quote Originally Posted by BriceO View Post
    It depends on the parameter. For a new design, you want the lowest values that affect the conduction and switching losses, so the forward voltage and switching time (related to gate charge) respectively. However when replacing a part you need to consider that the engineer will have matched the gate drive circuit to the particular IGBT, one would hope at least. Switching faster leads to more emi, so it's common to intentionally switch the devices more slowly (by increasing the gate series resistor) to reduce the emi to meet a specification. You could look at what gate resistors you have, versus the datasheet values - but bear in mind the datasheet isn't definitive. At best it's a good guideline, at worst it's a marketing document designed to make you buy the part.
    This sort of thing matters more with bigger devices, like these 900 Amp ones I've been playing with lately:
Name:	DSC07256 (Large).JPG
    I think the -3 is just designating that the part has three pins. One important thing to check is if the package of the ones you have has metal on the back, or is all plastic? If plastic, then you should either get the same or add insulation to the new ones (bit awkward).
    I think it's OK - the forward voltage is a bit higher so it will heat up more, but the current used with these spindles tends to be a lot less than the VFD rating so you will get away with it. If it breaks again you know what to do...
  1. Weird problem - stepped/staged deceleration on Huanyang 2.2kw Spindle
    By glynster in forum Spindles & Drive Motors
    Last Post: 25-01-2016, 01:39 PM
  2. Problem with Spindle not spinning
    By Noplace in forum Spindles & Drive Motors
    Last Post: 22-01-2016, 02:40 PM
  3. CONVERSION: Emco F1-p Mill Mach3 convention, Spindle motor problem
    By andre13442 in forum Conversion Build Logs
    Last Post: 14-01-2016, 12:14 PM
  4. Huanyang hy02d223b frequence convertor problem
    By frans cop in forum Motor Drivers & Controllers
    Last Post: 14-07-2015, 10:33 AM
  5. CNC spindle control VFD problem
    By djc in forum Motor Drivers & Controllers
    Last Post: 13-09-2009, 09:26 PM
