    Quote Originally Posted by jamhot View Post
    Hi Fred,
    Ok sound interesting. So does that mean whatever software you use to run the *.nc file, the coordinates are offset from/to this? Would this be a rule of thumb procedure before each job?
    Before you start wrecking your machine have a good read through this :-
    http://www.cnccookbook.com/CCDIYCNCBeginners.html
    It will help you understand what you are trying to achieve
    Brill - thanks Clive. I'll have a good read.
    To save your bed and table like metioned always cut air but if you want to see the actual cut then buy some thick insulation Foam and cut that first. This way gives enough time to react without damaging tool if goes wrong.
    Yeah good thinking - I thnk I need to get some blocks of wood or smilair material to test on (and use as a safty bed)! Thanks.
    wood will stick break tools soft but firm material is what you want.
    What material do you use, or would recommend? Thanks.
    Re read post #9
  1. NEW MEMBER: New memeber from west midlands
    By parminder in forum New Member Introductions
    Last Post: 15-02-2011, 05:04 AM
