    I decided a few years ago to build a cnc machine, fixed gantry/moving bed, started off a4, resized to a3 on paper, built machine then increase size to 1200 x 450, all works well large and small, aluminium, plastic and wood, I want to improve machine x axis and make it look better than frankestiens daughter it currently is, she is made from aluminium 40x40 solid box and 60 x 10 flat bar, my first question is will aluminium extrution be as strong or should I stay with solid box/bar, could box section work instead of the sold 40 x 40.
    Any help advice appriciated
    No pic as I am currently typing this from my hospital bed
    Steve
    Hey fella keep posting some guys n girls (i'm sure) on here that can help!
    Get well soon!
    Out of hospital all OK, going to have a look at Google sketch up, also been looking at 100 x 50 x 5 mm box section rather than solid box
    Any help/advice pleeeese
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by etched4u View Post
    Hi and welcome to the forum its difficult for people to give advise on the information you have given. Can you put up some pics of what you have and a bit more detail of what you are trying to achieve.
    I will be sorting a few pics of frankestiens daughter over next few days now I am out of hospital
    good news,
    Bright steel is what your looking at for straightness. This according to my welder friend.
    Quote Originally Posted by CNCKitMan View Post
    good news,
    Bright steel only means it has been polished. It has no bearing on any straightness or flatness. Your mate may have been referring to bight ground steel also known as drill blank. That comes in small packages and is expensive.
    https://emvioeng.com
    Well I'm not him, nor have I purchased what he suggested yet. He seems to think it's extruded. I may well have got the name wrong. That's just me. I've just used two equal angles from a wood burner as rails. Working fine.
    hows you fella? where'd you get to in the end??
    Quote Originally Posted by komatias View Post
    Bright Mild Steel has not been polished, it refers to mild steel in its bright drawn form which is significantly straighter and flatter than hot rolled mild steel.
  11. The Following User Says Thank You to jamesgates1000 For This Useful Post:
  1. NEW MEMBER: Hey from manchester
    By craigrobbo in forum New Member Introductions
    Last Post: 01-05-2012, 06:38 PM
  2. NEW MEMBER: Complete newbie from Manchester
    By jackdaniels in forum New Member Introductions
    Last Post: 04-12-2010, 01:37 PM
  3. NEW MEMBER: Hello from Manchester!
    By Dopy in forum New Member Introductions
    Last Post: 19-10-2010, 01:24 AM
  4. NEW MEMBER: Hello from Manchester
    By electricwizard in forum New Member Introductions
    Last Post: 26-08-2010, 02:08 PM
  5. NEW MEMBER: Hi from Manchester (ish)
    By the_mole_763682 in forum New Member Introductions
    Last Post: 11-06-2010, 12:39 AM
