    Eventually got time to finish off my coolant upgrade this afternoon.
    Got the tank and pump from Axminster, bargain at £130!
    Made up some side plates out of 2mm stainless steel and screwed them in position with some neoprene 3mm rubber sandwiched inbetween to stop any leaks. Worked well and no leaks so far!
    Did a few test cuts, 30mm dia pockets at 5mm deep, cutting 1mm at a time with a 6mm HSS 2 flute slot drill. Spindle running at 4000rpm with a feedrate of 800mm/min. Noticeable difference now it is flooded with coolant.
    Need to tidy pipe work up but will do that once I have got hold of some energy chain and then will do cabling at same time.
    Will sort your plates out tomorrow Lee.
Name:	Coolant system3.jpg
ID:	3169Click image for larger version.
Name:	Coolant system1.jpg
ID:	3170Click image for larger version.
Name:	Coolant system5.jpg
ID:	3171Click image for larger version.
Name:	Coolant system6.jpg
ID:	3172Click image for larger version.
Name:	Coolant system2.jpg
ID:	3173Click image for larger version.
Name:	Coolant system4.jpg
