27-01-2017 #5
You already have the motor kit at 150£.
Now search for the rails, at least the supported round rails (or hiwin rails if you want to cut metal with precision). Add 6 rails at your desired length plus 12 linear bearings.
Add 3 screws with nuts, ens support and coupling. If you want precision look at the ballscrews instead of the trapezoidal ones.
Add the cheapest spindle you can find, some sensors or switches, relays and of course all the cables.
If you still are under 500£, which I really doubt, add some aluminium or steel as the other components cannot levitate.
Small Fixed Gantry Router Spec and Build
By shaunrod in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 29-07-2016, 06:55 PM -
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
New member looking for advice on a good quality machine (brand)
By steve78 in forum Marketplace DiscussionReplies: 1Last Post: 16-08-2014, 09:25 PM -
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
BUILD LOG: New cnc router build looming, advice needed
By Mad Professor in forum DIY Router Build LogsReplies: 5Last Post: 06-11-2012, 08:12 PM
