Jesper I'll say it again just so you cannot say we didn't make it clear.!! . . . . The machine you describe CANNOT and I Repeat CANNOT be built for £500, not even close to £500.
I urge you to Listen and take advantage of MY experience. Over the years I've helped 100's of people like you who think CNC can be done on the Cheap and failed.! . .It Cannot.
Many of those helped where not Muppets but with skill sets ranging from road sweeper to Software and Electrical engineers in defense industry(Missle technician) so just because your in eletrical business doesn't follow you'll get this CNC business correct.!
Building a good reliable machine is more about knowing what NOT to buy than what will actually make it work. It's not just case of Sticking some motors on stepper drives and throwing power at it. Yes this will make it move but if components are not matched or inferior quality you'll always struggle and be dissapointed with the results.! . . And this is just the electrical side.
Again I'm urging you to Listen and go do lot more research before buying a single component. Not all is what it appears when comes to CNC just has your comment about Gecko G540 drive being better than Chinese offerings shows.? . . Once upon time maybe but not anymore.!
Good Luck:Last edited by JAZZCNC; 30-01-2017 at 08:48 PM.
31-01-2017 #2
In theory, not sure if it's possible in uk or dk, you can build a very strong and capable CNC with under £100 by hunting for components in scrap metal yards. You can find good rails, ballscrews, steppers, even servos, sensors, relays, cables, material for the frame, everything, sometimes at the cost of scrap-iron (£0.10?).
But you need very good knowledge of the components you are searching for, and A LOT OF TIME. I'm making a guess here saying 1000 hours (includes getting all the components, documentation, setup, tweaking, modifying, building, etc.). Now calculate how much do you earn for 1000 hours and tell me if it's worth it, in financial terms. On the other hand you'll learn a lot of interesting and useful things along the way.
PS. It's a pity that in our capitalist times a lot of very good components and machines are thrown away. They are no longer reliable in industrial production but still good, sometimes excelent for hobby.
31-01-2017 #3
01-02-2017 #4
06-02-2017 #5
Hi All,
I have read your comments and I will have to consider what to do. And although I - as you undoubtedly have noticed - had hoped that your replies would go in a different direction I nevertheless appreciate your considering & replying to this thread.
I also hope that you will let me know should you by any chance come across something that goes in the direction I've described (although it seems only remotely possible) ...
paulus.v. you have PM.
Cheers to you ;-)
Jesper
Small Fixed Gantry Router Spec and Build
By shaunrod in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 29-07-2016, 06:55 PM -
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
New member looking for advice on a good quality machine (brand)
By steve78 in forum Marketplace DiscussionReplies: 1Last Post: 16-08-2014, 09:25 PM -
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
BUILD LOG: New cnc router build looming, advice needed
By Mad Professor in forum DIY Router Build LogsReplies: 5Last Post: 06-11-2012, 08:12 PM
