Thread: 10mm belt and nema 23
27-01-2017 #1
Hi guys new here so hello to all,
I'm building DIY laser cutter, and as you now they got no load so can swing the x axis in mm per second,
I used 2 nema 23 That i had from a cnc build I did not use so thought I will use them on here, but I can only set steps to 3200 any lower and they stall bad even if I lower to 3mm second they stall, but looking at other lasers x axis swing looks fast at 300to500 when ingraveing but mine at 800mms looks slow, so I'm thinking if I went for a lower nema23 would speed be bit better, or if I put smaller pulley,
Specs are. 10mm belt, 20 tooth pulley, nema23 3008 1.8 angle, 1.9nm, 4.2 amps wired in parallel 8 wires,
Thanks guys for any info you can give, kev
10mm belt nema23
By kev20009 in forum Belt Drive, Pulleys & TimingReplies: 29Last Post: 31-01-2017, 05:19 AM -
Anyone have a UK source for open ended 10mm T5 Polyurethane belt
By cweeks in forum Linear & Rotary MotionReplies: 18Last Post: 19-03-2016, 09:43 AM -
WANTED: 2 nema 23's 76mm long dual shafts 6.35mm plus one 56mm long nema 23 dual shafgt 6.35
By nobby in forum Items WantedReplies: 0Last Post: 24-09-2014, 09:57 AM
