    Well the quick change uses too much Z up when I use a vice...
    So I have changed to using a collet holder - Er16, working well actually, except changing tools is a pig, and none of the tool heights are consistent so has to be reset all the time.
    So I figured I should buy a set of iso30 toolholders, and just have them dedicated to certain tools.
    Then its just a case of undoing the bolt on top the spindle housing, a light tap and out comes the tool holder, pop another one in...manually it was taking over a minute and getting the c spanner to catch is a pain, so I reached for my trusty impact driver. I can now undo without using the c spanner, so the swap takes about 10 seconds, and the tool height is repeatable, as long as the tool library in denford software is kept up to date and the tools numbered so I don't get confused.
    So now the theory worked, t I was trying to find some cheap iso30 tool holders, but all the ones I found to match my collet set and tolling I use were much more expensive. So I am going to try to switch to BT30, which from my reading is the same taper, but without the small turret on the top for the bolt to fasten into. Fingers crossed my bolt is long enough to reach into the bt30 holder, but I should know this weekend. If not I will be on the hunt for a longer bolt I can use with the BT30 holders, and I'll keep the shorter bolt for use with the iso30 tool holders (2 of them) that I have.
    I'll keep this thread updated as I go.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    A bit M12 threaded rod will work if needed.
  1. FOR SALE: Denford Novamill
    By m_c in forum Items For Sale
    Last Post: 27-01-2017, 04:41 PM
  2. FOR SALE: Denford Novamill for sale
    By Clive S in forum Items For Sale
    Last Post: 27-01-2017, 12:48 PM
  3. FOR SALE: for sale: Denford Novamill
    By Mash Govan in forum Items For Sale
    Last Post: 12-04-2016, 11:18 AM
  4. FOR SALE: novamill for sale
    By adamjackson1606 in forum Items For Sale
    Last Post: 26-02-2016, 05:07 PM
  5. What's best for a Novamill
    By leadinglights in forum General Discussion
    Last Post: 10-08-2010, 02:53 PM
