    Blowing air is much better for clearing chips than vacuuming.
    Ideal scenario is an £8 mist system from ebay coupled to a pot of WD40 and a compressed air supply.
    Neil...
    Build log...here
    Reducing the feed will not do much. You need to evacuate the chips and keep the cutter cool.
    With a carbide tool on, I have in the past, when out of soluble oil, just used compressed air with fine results.
    That said, how many flutes endmill did you use? Not good to use 4 unless you know what you are doing. Preference is 2 with a rapid helix to assist evacuation.
    https://emvioeng.com
    It was a four flute normal carbide end mill, and not the ones designed for aluminium.
    I have now tried the same but with a reduced depth of cut and reduced feed and it has done it well, albeit taking quite long.
    Guys, I have a lot to learn regarding the optimum feeds and depth of cut, and lots of tests to do, I don't want to run before I can walk. But I thought I would post my first experience as I am sure many of you have been there too:)
    Thank you for all the suggestions.
  1. Aluminium passivation - for aluminium to be used outside
    By CHudson in forum Metal Finishing Techniques
    Last Post: 06-04-2011, 09:18 PM
  2. HELP Gary, I'm having a disaster
    By Robin Hewitt in forum Linear & Rotary Motion
    Last Post: 16-04-2009, 10:07 AM
