Didn't offened but does frustrate because I wouldn't waste my time posting info trying to help if wasn't sure of what I'm saying so when someone with very little experience then try's to tell me I'm talking bo~%&oxs does slighty piss me off.
Just about every drive on the market as specified operating voltage range just like Gecko have and in theory they should work fine if voltage is within that range.
Now where the problem comes from is the fact Steppers can be and are used in wide range of applications. Lots of these applications will be slow moving or light weight applications so will produce very little inertia or back EMF. Then in which case provided regulated 50V supply is used there won't be any issue.
However for CNC router this isn't the case and inertia pushing gantry from high feeds so will create back emf and push the voltage above the 50v safe limit.! . . Ahh but where using Regulated supply your thinking so no problem. .
. . . .Wrong now you create another problem.?
Regulated supplies will have protection built into them so if voltage/current is feed back it clamps the supply and shuts down.! . . . Not good.
So you see it's not so black and white.
Now do your self a favor contact Gecko USA not your supplier and tell them the problem and I'm sure they will help you or advise what it could be.
Or better still do your self Bigger favor and sell it then buy Leadshine AM882 Digital drives and use Unregulated toroidal supply. The difference in machine performance will be night and day and you'll never have any issues.
05-02-2017 #2
Totally agree! I've got the AM882 drives on his recommendation and I'm very satisfied by their performance. Lower noise and vibrations, better performance at high speeds, software configuration, auto-tunning, etc. And you can give your steppers 60-65V for better performance.
05-02-2017 #3
Well - I've got the G540 working on 30 volts with the 4 motors, I've just had to ramp down the voltage significantly to achieve it.
Looked at the leadshine - are you using a Bob or some other thing to break the sigs out into a useable format to run wires?
I ran the G540 for a 7 hour job, and it completed without any problems, so - apart from the fault causing me to run slower, I'm going to reserve my judgement - hopefully there is a simple fix
I'm going to call Gecko tomorrow and see if I can get anywhere with them.
05-02-2017 #4
07-02-2017 #5
Update - I finally skyped tech support, and they have been great.
The problem appears to be the result of several factors, but is related to switching power supply / 4 motor combo / and a setting on the G540
Gecko are testing out a mod to the G540 to see if they can get it to work with this power supply in particular, and the 4 motors I have.
I'll let you know the result incase others have the same issue.
Nick
21-02-2017 #6
21-02-2017 #7
Better still scrap the outdated Gecko and get something at least designed in this century.
John S -
X2 Mill motor Problem
By A11an in forum Milling Machines, Builds & ConversionsReplies: 18Last Post: 20-01-2022, 12:26 PM -
Problem with my Gecko G540 control unit.
By 1albobs in forum General DiscussionReplies: 15Last Post: 19-05-2021, 08:06 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM -
Motor problem
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-09-2009, 01:06 AM -
Motor / drive wiring problem: help!
By lateAtNight in forum General ElectronicsReplies: 2Last Post: 29-04-2009, 07:40 PM
