Update - I finally skyped tech support, and they have been great.
The problem appears to be the result of several factors, but is related to switching power supply / 4 motor combo / and a setting on the G540
Gecko are testing out a mod to the G540 to see if they can get it to work with this power supply in particular, and the 4 motors I have.
I'll let you know the result incase others have the same issue.
Nick
21-02-2017 #2
21-02-2017 #3
Better still scrap the outdated Gecko and get something at least designed in this century.
John S -
21-02-2017 #4
We will see, if the new power supply fixes the problem, I'm happy. If not I will probably try the leadshine the am882 quite cheap now it's no longer made, much different to new em series? . It's by no means a "cheap" change so we will see.
I did get my x axis running at 18,000 mm/min when I changed to the 42 volt pwr from 30 volt, so I should get another increase going to the max 50.
To clarify gecko tech support told me that 48 volt should be fine to use, and anything up to 50 volt should be fine with this system. IE it is designed and tested to run at higher voltages, and downrated to 50 volts for the consumer to avoid issues and to include a large enough safety buffer. Anything that fails below 50 is an anomaly.Last edited by dachopper; 21-02-2017 at 11:20 AM. Reason: Add
21-02-2017 #5
21-02-2017 #6
Is $40 per am882 a good price?
21-02-2017 #7
21-02-2017 #8
21-02-2017 #9
X2 Mill motor Problem
By A11an in forum Milling Machines, Builds & ConversionsReplies: 18Last Post: 20-01-2022, 12:26 PM -
Problem with my Gecko G540 control unit.
By 1albobs in forum General DiscussionReplies: 15Last Post: 19-05-2021, 08:06 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM -
Motor problem
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-09-2009, 01:06 AM -
Motor / drive wiring problem: help!
By lateAtNight in forum General ElectronicsReplies: 2Last Post: 29-04-2009, 07:40 PM
