27-01-2017 #6
As Clive says, the kits are often put together using less than ideal choices of components. In this case, I would guess that the kit uses a switch-mode power supply because these are smaller, lighter, and in particular cheaper than a linear supply, which is the preferred option from a purely technical viewpoint. The linear supply can cope with peak overload without breaking into a sweat where the SMPS can trip internal overload protection. I'm a bit surprised as well that there is a problem, though, but seeing that it appears to be load-related, and is a bit variable suggesting that perhaps it is when all motors are trying to deliver pulses simultaneously which won't happen all the time, maybe it is the PSU. Does seem on the face of it to be the most likely issue. My own machine uses small, cheap SMPS boxes for control circuitry where the load is smaller and well-defined (very cost-effective here) but I use a linear supply for the stepper drivers.
X2 Mill motor Problem
By A11an in forum Milling Machines, Builds & ConversionsReplies: 18Last Post: 20-01-2022, 12:26 PM -
Problem with my Gecko G540 control unit.
By 1albobs in forum General DiscussionReplies: 15Last Post: 19-05-2021, 08:06 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM -
Motor problem
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-09-2009, 01:06 AM -
Motor / drive wiring problem: help!
By lateAtNight in forum General ElectronicsReplies: 2Last Post: 29-04-2009, 07:40 PM
