  1. #32
    We will see, if the new power supply fixes the problem, I'm happy. If not I will probably try the leadshine the am882 quite cheap now it's no longer made, much different to new em series? . It's by no means a "cheap" change so we will see.
    I did get my x axis running at 18,000 mm/min when I changed to the 42 volt pwr from 30 volt, so I should get another increase going to the max 50.
    To clarify gecko tech support told me that 48 volt should be fine to use, and anything up to 50 volt should be fine with this system. IE it is designed and tested to run at higher voltages, and downrated to 50 volts for the consumer to avoid issues and to include a large enough safety buffer. Anything that fails below 50 is an anomaly.
  1. X2 Mill motor Problem
    By A11an in forum Milling Machines, Builds & Conversions
    Last Post: 20-01-2022, 12:26 PM
  2. Problem with my Gecko G540 control unit.
    By 1albobs in forum General Discussion
    Last Post: 19-05-2021, 08:06 PM
  3. Replies: 1
    Last Post: 25-12-2010, 06:05 PM
  4. Motor problem
    By irving2008 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2009, 01:06 AM
  5. Motor / drive wiring problem: help!
    By lateAtNight in forum General Electronics
    Last Post: 29-04-2009, 07:40 PM
