27-01-2017 #5
That size power supply should be fine. As these are modern chopper style drives, they won't actually draw the full 3.5A from the power supply unless you are really pushing all the motors hard at speed, which is quite unlikely.
It could however be a problem with the power supply. Ideally I'd connect an oscilloscope over the power supply, and see what is happening with all the motors connected.
You may be able to catch any dip in voltage with a voltmeter, as the dip would likely have to last for a second or two for the drive voltage to drop low enough to cause problems.
Does the power supply have any kind of voltage OK output? it may be worth connecting up a lamp to see if the power supply is shutting down when the problem happens.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
X2 Mill motor Problem
By A11an in forum Milling Machines, Builds & ConversionsReplies: 18Last Post: 20-01-2022, 12:26 PM -
Problem with my Gecko G540 control unit.
By 1albobs in forum General DiscussionReplies: 15Last Post: 19-05-2021, 08:06 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM -
Motor problem
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-09-2009, 01:06 AM -
Motor / drive wiring problem: help!
By lateAtNight in forum General ElectronicsReplies: 2Last Post: 29-04-2009, 07:40 PM
