    With the 3.5A tuning and your power supply the gecko should work 100% fine. I suspect there is something tripping the chargepump.
    What are you using to drive the Gecko? parallel port? Is that conking out and causing the chargepump to go low?
    https://emvioeng.com
    This is my power supply http://www.automationtechnologiesinc...upply/48v12-5a
    I have the G540, connected with the DSUB ribbon to UC400ETH controller, then that goes Cat5 cable to a switch, and cat5 to my laptop.
    When the fault occurs, the connection between the UC400ETH and Laptop and UCCNC program looks normal ( the G540 disables the servo's from moving, and the UCCNC software shows that the motors are still being told to move without any limit switch activation.
    I noticed aswell, a little noise from the servo's when they are stationary and they are all connected, but less when there are 1 or 2 or 3 motors connected is this normal?
    I've checked the resistors and they are 100% correctly installed, and re-wired the power supply to G5540 + and - with other 14G braded wire last night
    Another thought
    To troubleshoot the power supply, I have a Mastech 30 Volt 10 Amp variable DC switching power supply.
    Should I plug this in ( although it's only 30 volts, and the other one is 48 volts ) and see if there is a difference?
    Nick
    I experimented again with the power supply and g540 , thismorning.
    My other power supply, is only 30 Volt max 10 amps, but I can see the current draw on the system was down around 2-3 amps ( don't know how accurate that is ) I could not get the fault with the other system.
    I then tried the keeling 48 volt 12.5 amp
    with voltmeter on the output, it was steady but faulted at 48 volts, I adjusted the voltage pot to 49.9 volts, again stable, the multimeter coult not detect movement, but the fault happened faster at 50 volts, I dropped voltage to 46 volts, and faulted after 5 minute, then I tried 44 volts, and it took lots of simultaneous input, but it eventually gave a fault at 44 volts, I wound the pot all the way back, so it's now at 42.5 volts, and there was no fault so far.
    sound like there is a feedback issue coming from somewhere?
    Is there anything I can do to try make it work at 48 / 50 volts
    Personally I would build a toroidal transformer type power supply
    4x3.5A =14A and you have a 12.5A PSU. Am I missing something?
    For a switching power supply you need to be at least 18A.
    (edit: I may be wrong here but Leadshine, among others, recommend adding 1/3 more to the rated motor current when using a switching PSU; 4*3.5*4/3=18.66A).
    For a linear one you will be fine with 10A.
    (edit: a bipolar parallel steppper requires a maximum of 2/3 of the rated amps/phase; 4*3.5*2/3=9.33A).
    I would go with a toroidal PSU as Clive said.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    In short, yes.
    And before I give a Jazz style response about people commenting on things they don't understand, go and read the gecko drive stepper motor basics guide, as they explain quite well all about power supply requirements for stepper drives.
    Quote Originally Posted by dachopper View Post
    Provided you're remaining below the maximum voltage of the gecko drives, and allowing a reasonable safety margin, it should make no difference.
    I can't remember, but are there any LEDs on the G540 to let you know any statuses?
    I'd suggest temporarily disabling the chargepump input on the G540, and see if fault still occurs. It could be a noise issue that with the higher power, the G540 isn't seeing a good charge pump signal, so it is disabling all the drives. However if that was the case, I would expect problems with the step/dir signals aswell, however that probably wouldn't be noticeable if you're not actually working the machine to notice a position loss.
    The Charge Pump was disabled when the issue began, I enabled it and the issue remained
  1. X2 Mill motor Problem
    By A11an in forum Milling Machines, Builds & Conversions
    Last Post: 20-01-2022, 12:26 PM
  2. Problem with my Gecko G540 control unit.
    By 1albobs in forum General Discussion
    Last Post: 19-05-2021, 08:06 PM
  3. Replies: 1
    Last Post: 25-12-2010, 06:05 PM
  4. Motor problem
    By irving2008 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2009, 01:06 AM
  5. Motor / drive wiring problem: help!
    By lateAtNight in forum General Electronics
    Last Post: 29-04-2009, 07:40 PM
