29-01-2017 #11
I get your point and I do agree on lot of it.! However your just has guilty the others for dismissing Known Good advise by not listening to or trying to put down experienced people like ME.! . . . Do you think I'd go to the trouble of buying more expenisive transformers and Drives which can handle higher voltages if I didn't KNOW there was benifit in doing so.? . . . . No I wouldn't.
Can I give you the calculations and science behind why then NO I can't.!! . . . . All can tell you is I just build the bloody things and thru lots trial error plus lot of patience found that 70Vdc works better for router than 54Vdc which calcs show for same motor..!! . . . . I don't need pyhisics or calculations to tell me this it's obvious from machines performance and to me that's all that matters.
I liken it to what Manufacturers recommend for Octane rating for engines best performance.!!. . . . . But you don't see many performance cars using fuel from your local esso garage do ya.!!
X2 Mill motor Problem
By A11an in forum Milling Machines, Builds & ConversionsReplies: 18Last Post: 20-01-2022, 12:26 PM -
Problem with my Gecko G540 control unit.
By 1albobs in forum General DiscussionReplies: 15Last Post: 19-05-2021, 08:06 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM -
Motor problem
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-09-2009, 01:06 AM -
Motor / drive wiring problem: help!
By lateAtNight in forum General ElectronicsReplies: 2Last Post: 29-04-2009, 07:40 PM
