    Ignoring Voltage/Power supply discussions, what is the actual fault you are seeing?
    Do the motors stop/stall, the drives fault out...?
    It's reading the CNC code, then the Gecko unit fault light somes on and that disabled everything
    Is seems to happen a lot more - the higher the voltage I set on the switch mode power supply, I thought I had it working on the 42Volt setting, which is the lowest possible, but it stopped 3-4 times around the same area in the workpiece today
    I tried to re-do it at slow speed, with slower accelerations and it still stopped - it's not jamming, it's running at about 30% of the jamming speed, it's being turned off because Gecko is giving a fault for some reason. the CNC program is still happily running in the background sending commands out
    I switched over to another lower 30 Volt switched power supply that is also half the power ( 300 Watt ) , and I've had to slow down the motors and accelerations even more, as it's now almost half the efficient voltage I need. It seems to be getting through the job, although I had a few missed steps due to high loading at times during the cut sequence - so I've reduced the speed/accel even more
    I don't know if it's a power problem, or a geckodrive current draw issue, or voltage issue - mystified
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    My guess is you have a noise problem, which is made worse by the higher voltage.
    I've just had a quick scan of the G540 manual. How have you connected pin 10 and 12 on the G540? Have you tried connecting them with just a short bit wire?
    The G540 uses 4 G250s internally, which don't have any form of fault output, so an individual axis fault should not cause the G540 fault light to come on.
    I've got a wire - about 2 foot long which is connecting them both together, I'll have a go - and shorten it right up, but I doubt this is the issue, then again, the + and _ wires run right next to this wire at the G540 box. -I heard there was some form of overvoltage protection, so I assumed that was what was faulting.
    Wow - I just found this thread..
    Guy has exactly the same motors as me, and the same fault.
    http://www.cnczone.com/forums/gecko-...connected.html
    Quote Originally Posted by dachopper View Post
    But they fixed the problem in their G540 4 years ago. Is your Gecko that old?
  1. X2 Mill motor Problem
    By A11an in forum Milling Machines, Builds & Conversions
    Last Post: 20-01-2022, 12:26 PM
  2. Problem with my Gecko G540 control unit.
    By 1albobs in forum General Discussion
    Last Post: 19-05-2021, 08:06 PM
  3. Replies: 1
    Last Post: 25-12-2010, 06:05 PM
  4. Motor problem
    By irving2008 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2009, 01:06 AM
  5. Motor / drive wiring problem: help!
    By lateAtNight in forum General Electronics
    Last Post: 29-04-2009, 07:40 PM
