    MDF would usually be cut with a router bit because it is abrasive, aluminium alloy with a high helix milling cutter, pure aluminium is best cold formed because it really doesn't want to cut at all, horrible stuff. A stub cutter could go faster than a long series cutter so this is hard to guess. If you had it on the machining centre it is designed for then it would have a jet of coolant/lube on it keeping the cutter clear and cold. Without lube aluminium oxide will build up on the cutting edge which then ceases to be a cutting edge just before the tool breaks. I find surface finish is usually a bit naff from smaller cutters in aluminium but that could just be because I zoom in on the jolly old camera with small tooling. I need to guess a feed rate for a 2mm tool in aluminium alloy, I guess 1.5mm/s.
  2. The Following User Says Thank You to Robin Hewitt For This Useful Post:
  1. Speeds and feeds
    By eurikain in forum Workshop & Equipment
    Last Post: 26-03-2016, 06:00 PM
  2. Feeds and speeds software
    By suesi34e in forum Swarf & Chip Management
    Last Post: 22-03-2016, 10:30 PM
  3. Feeds and speeds software?
    By Leadhead in forum Computer Software
    Last Post: 31-10-2015, 09:34 PM
  4. Feeds and speeds
    By dudz in forum Tool & Tooling Technology
    Last Post: 26-08-2013, 11:42 AM
  5. Speeds and Feeds
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 20-09-2012, 01:38 PM
