Thread: Parallel issues
28-01-2017 #1
Hey guys.
So i am new to CNC's.
I recently purchased a 1000mm x 1000mm machine used.
Its main uses will be making things as a hobby, and i haven't quite worked out where to house it, or keep it stood up (is that bad for the machine?).
It is belt driven and uses a Kess 1050 FME-1 router.
Aside from noticing there are parts missing (Nut and collet, and Power cable for the Kress) after i collected it (Things i didnt think to look out for). The machine is not bad, well i THINK.
So i have an issue from the outset.
The control board is a CNC4X45A which has a parallel interface, given i use Windows 10 64 bit on my only laptop.
I dont really want a whole desktop, with associated peripherals living in my flat, or any where really because of the lack of space.
Ideally i would like to be able to use my laptop for designing and cutting.
I have heard there is an issue with "love data" on usb connections hence parallel is always better.
So i understand there are numerous options:
1. Chinese USB CNC controllers
2. U100 (Some form of converter dongle).
3. Parallel to USB Converter
4. USBCNC controller (recommended by robocutters).
Any ideas?
If worse does come to worse i will purchase a desktop then in some way mount it underneath the CNC, or above it even.
Thanks in advance
28-01-2017 #2
Hi.you can't use Windows 10 64bit with a parallel cable. You will need to use an Ethernet board. Windows 10 turns off the parallel cable so makes it useless for Inc.you are better using a old Windows 7 desktop.believe me I wasted weeks trying to get the breakout board to work with my new Windows 10 pc. Using a old 40 pound Windows 7 machine it all worked within the hour
28-01-2017 #3
#2 is your best option, and if you don't already have a Mach3 license, use UCCNC software, which is better, and much cheaper.
ANd it's not a converter, but a motion controller.
Converters do not work.Last edited by Ger21; 28-01-2017 at 05:22 PM.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
28-01-2017 #4
I would buy a desktop PC to be used exclusive for the CNC control software. There are nice cheap minitower PC like Dell Optiplex. You have to make sure the PC is old enough to have the parallel port on board.
29-01-2017 #5
29-01-2017 #6
So i am eager to get this machine going. So found a cheap desktop with monitor for £25 with 4gb of ram and a rghz processor lol.
I will use this while i get this machine set up and look at the UC100 or a ethernet based one. Do you have any recommendations?.
So mach3 is set up (a friend of mine had a spare licence from one of his projects).
But i cant seem to get the machine to work :S
29-01-2017 #7
there is a lot in setting up mach3, first check pp is checked and correct number, you need a emergecny stop connected or put 0 where 10 is this over rides it, then you need to select high or low for limit switches to work, check where the drivers are numbered in breakout board, you need to put these numbers in motor output like 2x3 x axis 4x5 y axis 6x7 z axis 8x9 for a axis if used, then you need to check if you motors are high or low, by putting a tick you should hear them lock in,
29-01-2017 #8
My preference would be from Cslabs but not cheap depending on if you need slaved motors or not. However the UC300ETH would be my second choice provided it's connected to good breakout board that can provide 24V I/O.
When you say Mach is setup do you mean it's just been installed or you have set it up with all the correct pin numbers etc.
Just installing mach3 won't make the mach work. To work you need to tell mach3 where to look for incoming signals and where to send out going signals. To do this you'll need some info about how the machine is wired. This is known as the I/O system (input/Output) and if set wrong machine won't do anything.
If you don't know which pins are connected to what and can't get the info then you'll need to take very detailed pics and post so we can work out what hardware you have and whats going to where.
29-01-2017 #9
Ethernet motion controller on a belt driven CNC with a Kress router? Isn't it a bit overkill? Of course you recommended the best price/value controllers but if this router had been mine, the first upgrade would have been ballscrews, not a fancy industrial grade motion controller. And the second, the spindle and still happy with the old printer port
It's probably because I enjoyed learning about the parallel port while trying to use a laptop for my cnc and bought a BoB kit, with filtering and signal conditioning chips, soldered by me piece by piece. I still respect my first BoB and it still serves me well
29-01-2017 #10Gerry
SEM DC Motor Issues
By Chaz in forum General ElectronicsReplies: 11Last Post: 21-05-2019, 10:10 AM -
Engraving issues
By D-man in forum Machine DiscussionReplies: 50Last Post: 29-02-2016, 10:01 AM -
50w laser - PSU issues?
By calida in forum Laser Machines & BuildingReplies: 1Last Post: 09-02-2016, 04:25 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
Page layout issues...
By irving2008 in forum General DiscussionReplies: 3Last Post: 09-08-2012, 08:10 PM
