Thread: Parallel issues
    Quote Originally Posted by CrazeUK View Post
    So i am eager to get this machine going. So found a cheap desktop with monitor for £25 with 4gb of ram and a rghz processor lol.
    I will use this while i get this machine set up and look at the UC100 or a ethernet based one. Do you have any recommendations?.
    My preference would be from Cslabs but not cheap depending on if you need slaved motors or not. However the UC300ETH would be my second choice provided it's connected to good breakout board that can provide 24V I/O.
    So mach3 is set up (a friend of mine had a spare licence from one of his projects).
    But i cant seem to get the machine to work :S
    When you say Mach is setup do you mean it's just been installed or you have set it up with all the correct pin numbers etc.
    Just installing mach3 won't make the mach work. To work you need to tell mach3 where to look for incoming signals and where to send out going signals. To do this you'll need some info about how the machine is wired. This is known as the I/O system (input/Output) and if set wrong machine won't do anything.
    If you don't know which pins are connected to what and can't get the info then you'll need to take very detailed pics and post so we can work out what hardware you have and whats going to where.
    Ethernet motion controller on a belt driven CNC with a Kress router? Isn't it a bit overkill? Of course you recommended the best price/value controllers but if this router had been mine, the first upgrade would have been ballscrews, not a fancy industrial grade motion controller. And the second, the spindle and still happy with the old printer port
    It's probably because I enjoyed learning about the parallel port while trying to use a laptop for my cnc and bought a BoB kit, with filtering and signal conditioning chips, soldered by me piece by piece. I still respect my first BoB and it still serves me well
    This the difference between you and me.!! . . . . . I wouldn't waste my time trying to upgrade in first place but he didn't ask me that question did he.!!
    In any case not really overkill because he'll be needing this for second machine when he finally accepts and realises he's wasting his time trying to make silk purse out of sows ear.!! . . . . Time you folks started smelling the roses and accepting the fact the Parallel port is dead.!
    I'm hoping that by the time it stops kicking so will the PC based controller and the stand alone control boxes will have sufficiently matured :D
    You and me both.!! . . . But I'm not holding my breath.
    At the time when i wrote that, it was just Mach3. Then i managed to work out all the pins by trial and error.
    It worked really well. Since then i tried to calibrate via settings Alt6. I hit the reset button in there, it now doesn't do anything :S - Well i hear the Control board click every now and again.
  1. SEM DC Motor Issues
    By Chaz in forum General Electronics
    Last Post: 21-05-2019, 10:10 AM
  2. Engraving issues
    By D-man in forum Machine Discussion
    Last Post: 29-02-2016, 10:01 AM
  3. 50w laser - PSU issues?
    By calida in forum Laser Machines & Building
    Last Post: 09-02-2016, 04:25 PM
  4. Limit switch issues?!?
    By jonbabbz in forum General Electronics
    Last Post: 06-02-2014, 07:37 PM
  5. Page layout issues...
    Last Post: 09-08-2012, 08:10 PM
