Thread: Kress 1050 FME-1 Parts
Hey guys i am looking for:
A Power cable
a NUt and some collets.
If any one has any?
30-01-2017 #2
Kress Spares Service don't give out prices on the internet to outside of Germany. You can see what is available http://spareparts.kress-elektrik.de/...7o2mb12033c147 but you will need to put them in the basket to start a conversation on price.
Otherwise -----
This is about the cheapest I can find https://www.sorotec.de/shop/Collets/...dle-motor.html and they sell the clamp nuts https://www.sorotec.de/shop/Collets/...ew-model-.html If you can afford it get a couple of clamp nuts. I currently have 5, because changing the collet in the nut is a pain in the arse.
Is this the cable you need ? https://www.sorotec.de/shop/Spindles...-4-meters.html
You'll be lucky if you find any preloved ones.
Cheers,
Rob
30-01-2017 #3
30-01-2017 #4
The Kress Routers are fairly sturdy and well built for what they are, but they have their own collet and nut design. You might find someone selling their whole Kress kit if they are moving on to a VFD and spindle.
Cheers,
Rob
30-01-2017 #5
31-01-2017 #6
Routers are generally single phase motors with brushes, not really suited to long switch-on periods. VFD means Variable Frequency Drive and it has 3 phase output at a changeable frequency so you can control the speed and direction of the Spindle, which is a 3 phase motor, usually brushless, so more suitable for continuous use.
Cheers,
Rob
The Following User Says Thank You to cropwell For This Useful Post:
31-01-2017 #7
I don't have the Kress, but know that CNC-Plus is selling it and also sells spare parts.
https://cnc-plus.de/
Also Sorotec sells it.
I am a regular customer at these companies and in my experience they are very reliable, shipping fast and for a reasonable cost. I am very happy with the quality they deliver and the service they provide.
In fact, I originally wanted to use Kress but discarded it partially due to the collet they are using, which is non-standard. It is pretty expensive to have a collection of them, especially if you want a few of each dimension which are frequently used as well. The other thing is that it is just an ordinary one phase motor, like an angle grinder. I think that a VFD and a spindle is a better alternative and in the end, with all the extra collets I have, is not even more expensive.Last edited by A_Camera; 31-01-2017 at 10:10 AM.
31-01-2017 #8
Hey thanks for these links, I'll check them out. The parts for this thing do seem really expensive, and limited in number of suppliers. I think, I'll get a collet, nut, and cable and maybe sell it and invest in a vfd and spindle.
What size collet would you say is standard?
Sent from my SM-N930F using Tapatalk
31-01-2017 #9
That depends on what you work with and which cutters you are using. I have 10 x 1/8" 10 x 4mm and 10 x 6mm ER11 collets, apart from the complete ER11 series. I am using a lot of very small tools and I find it easiest to have a large collection of collets and collet nuts. If I wanted to have the same set for Kress I'd had to spend a small fortune on these. ER11 and ER16 collets are cheap, so it is no big deal buying these in large numbers.
01-02-2017 #10
So basically i should at some point sell the Kress and get a spindle?
I am looking into a VFD and a spindle set up, going to see how much it would cost to convert.
FOr the kress, just to get me playing, do you recommend any "standard" size that i can get bits for easily - i.e. off fleabay to experiment with.
e.g. A 8mm collet may house a number of different sized bits that are thinner or types
By CrazeUK in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 28-02-2017, 03:46 AM -
eBay: Kress 1050 FME-1 Spindle
By viz in forum Items On eBay UKReplies: 0Last Post: 21-08-2013, 04:04 PM -
eBay: Kress 1050 FME router
By rbs in forum Items On eBay UKReplies: 12Last Post: 08-05-2012, 12:40 PM -
Where's the cheapest place to buy a Kress 1050?
By Jonathan in forum Marketplace DiscussionReplies: 30Last Post: 05-01-2011, 07:00 PM -
collets for a Kress 1050
By groov in forum Kress Milling MotorsReplies: 5Last Post: 20-08-2009, 11:54 PM
